Use statistics to help you monitor Open Shortest Path First (OSPF) performance. You can also use statistics in troubleshooting procedures.
This command provides values for brouter port implementations. For IP protocol-based VLAN interface statistics, use View the OSPF Interface Statistics.
View basic OSPF statistics:
Switch:1>enable
Switch:1#show ports statistics ospf main
Port Stats Ospf
PORT_NUM RX_HELLO TX_HELLO RXDB_DESCR TXDB_DESCR RXLS_UPDATE TXLS_UPDATE
1/3 0 0 0 0 0 0
Use the data in the following table to use the show ports statistics ospf main command.
Variable |
Value |
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} |
Identifies the
slot and port in one of the following formats:
